メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年3月に発表され、同年4月10日に発売されました。Galaxy S6 Edgeは Samsungの最新のスマートフォンで曲面ディスプレイをもつデバイスです。
None of the buttons working, and there is a blue box around task bar
I took a screenshot, and now I can't use any of the buttons (including the soft buttons), and there is a blue box around the task bar. I can't shut it off, pull down the task bar, or receive calls or texts. I CAN take a screenshot, and scroll on the screen. It's stuck on the web browser.
EDIT: I still have no idea what that was, but I was able to hard shut off, and it works now!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
This is late, but I'll just leave it here anyway, the same thing happened to my dad trying to take a screenshot and he might've missed.
All you need to do for anyone looking is to hold on the Volume Up + Power button until you get a pop-up saying the thing was disabled. (: 3s should do the trick & hope anyone seeing this takes care xoxo
さんによる
How do you get it off
さんによる
コメントを追加
2件の回答
ベストアンサー
Sounds like you had voice over on, which is an aid for users with visual impairment.
If I remember correctly you activate and deactivate it by triple tapping the home button.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
You click on the button you want. Then double click the home button to activate that app. To turn off, click the settings button so it’s outlined in blue. Double click the home button to open settings. Click the search magnifying glass. Double click home. Type talk and you should see the talk back option. Then repeat the click double click on the off feature of talk back. That’s should get it turn off and back to normal operation.
さんによる
コメントを追加
To get started press first number of password then voice will say double tap. Continue with rest of password double tap after every number plus ok. This should open tablet. Then press volume button turn off voice assistant. Worked for me.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kai B さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 21
今までの合計 9,211
