メインコンテンツにスキップ
12.2 MP camera released by Samsung in 2009.
4回答 すべてを表示
What if my camera got put in the washer and got wet
What do I do if camera got wet
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi,
As you know water and electronics and electricity are not a good mix.
The water causes corrosion and provides circuit paths for the electricity which were not in the camera's operating design and could damage the components.
First do not turn on your camera and then you need to remove the battery as soon as possible from the camera to minimize any further damage.
Then you need to dis-assemble the rest of the camera and clean all the affected parts using Isopropyl Alcohol 90%+ (available from electronics parts stores) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents and is not as effective. If you do use it, check the label to verify the amount of IPA.
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the boards.
Hopefully after you have done all this the camera might possibly work correctly again.
Here is a link to the ifixit guide(s) for repairing your camera, which may be of some help. Samsung TL220
Here’s a link to a video, which shows how to dis-assemble your camera, which may also be of some help.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Francisco Hinojosa Jr さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 48
