I have a bad lockup silinoid for transmission
is there a inter change list for 99 honda accord?
According to Wikipedia, you might score a solenoid from an Acura CL, Acura MDX, Acura TL, Honda Inspire, or a Honda Odyssey.
このアンサーは役に立ちましたか?
This is a very common problem, remove the solenoid, inspect the oil screen, clean as needed. If it was clogged then maybe you will be lucky and no parts needed. This repair is available all over the internet. Buy the correct part for your transmission and any related parts such as the screen if it does not come with the solenoid. Be sure the wiring is good.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 48
