Why are the lnes in the center of my new able
My tablet has lnes in the middle ts red at times an today it's white have seen v3 lines at times new tablet only a few weeks have seen up to 3 different color of lnes don't have anyideal what to try
Jerry Hardee could be an issue with the LCD TAB connection. Post an image of what those lines look like iFixitでの質問に画像を追加する方法 If it is the TAB’s then it is not a DIY repair but needs a replacment LCD
このアンサーは役に立ちましたか?
bruh I already basically said that why do you need to repeat it?
bruh? LMBO! I repeat it because your answer is very convoluted and not very clear. Yes, you added the TAB after but seem to forget that things like "pixels to the motherboard" is really very nondescript. The lines maybe a pixel wide but no pixel will ever connect to anything. A pixel is nothing but the smallest unit of a digital image that can be displayed.
Still have lines will try to find some way to return it hopefully they will repair or replace it
this problem is caused by loose cables and no connetion in the pixels to the motherboard aka TAB
このアンサーは役に立ちましたか?
it can be fixed because if you push on the spot on the edge it goes away how take it apart and push on all edges of screen
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 35
