do I need certain type of hard drive to back up DOS & Windows XP?
I need a portable back up of a DOS program on this old computer. Should I use a hard drive or can I use a USB flash drive?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Either one. It’s predicated on just how much data you have to back up. Cost per gigabyte is going to be lower on an external hard drive.
このアンサーは役に立ちましたか?
Margaret —
You could use either one, but USB flash drive will be easier since connection is so simple. You don’t even need to open up the computer, as you would to connect a non-USB hard drive.
Good luck,
Russ
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 123
1件のコメント
Incidentally, this system can be upgraded to Windows 10. Just checked.
mike さんによる
