メインコンテンツにスキップ
2011年7月21日に発売されたMac Mini Mid 2011モデルはCore i5もしくはCore i7プロセッサ、Thunderboltを搭載しています。
204回答 すべてを表示
Can you add a 2nd HDD to the $799 Mac Mini?
I've looked at the teardown and I must ask if anyone knows if you can add a 2nd HD to the $799 Mac Mini. The reason I ask is because you cannot get the AMD Radeon HD 6630M Graphics card and a second hard drive.
If I buy a $799 Mac Mini and choose to add a second HDD will there still be room or does the Radeon HD 6630M card get in the way?
I want the server version, but you have no choice on graphics cards. Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
I can confirm I was able to install a 2nd drive in mine just fine. In fact I replaced the stock 500G drive and installed two SAMSUNG Spinpoint M8 HN-M101MBB 1TB 5400 RPM 8MB Cache 2.5" SATA 3.0Gb/s Internal Notebook Hard Drive -Bare Drive from newegg.com.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
+ what cabling did you use?
さんによる
I used the cable sold by iFixit.com, and the original Apple cable. I did peel off the black plastic from Apple's drive and transfer it to the new drive. Don't want any shorting.
さんによる
コメントを追加
As far as I know there's no definitive answer yet. I guess we're waiting for someone to actually obtain the required cable and successfully fit a second drive in a 2011 mini with Radeon 6630M. It certainly looked like there was room in mine when I fitted my SSD the other day. It had the space under the HD just like in the teardown of the Intel-graphics-only mini. As soon as it's confirmed possible I'll be adding a second drive to mine for Windows.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Shane Whitford さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 2,150
