Freezer not freezing solid, ice pops and veggies are thawing
I have a GE profile performance (SN:RZ211108 MODEL #:TFX26PPDA WW) side by side from 2000ish. The condensor fan and evaporator fan are working and I just cleaned the dirt off the coils underneath in the back. Not enough time has passed for me to know if this fixed the issue, but it seems to not have worked (hour or so after). It was fine since I moved in a month ago, it would super freeze/cool anything. This is all of the sudden.
I also can feel the compressor vibrating so I assume it's running (then again, what do I know). The temperature settings are both on 9 and I might as well mention that there was some water underneath it when I moved it out as well. I'm thinking that maybe there's some frozen coils I can't see or something. *Update* Checked the coils on the inside and there's no frost. Maybe it's a thermostat problem?
Thanks for your help
この質問は役に立ちましたか?
