メインコンテンツにスキップ
Samung 28" 4K UHD Monitor. Model #LU28E510DS/ZA.
5回答 すべてを表示
Can I add my spare samsung tv speaker on Samsung U28E510 Motherboard?
I have Samsung TV speakers & want to add these on Samsung U28E510 monitor Motherboard. Is it possible if Samsung U28E510 Motherboard have the audio port to add these speakers? Pls find the mother board picture I found on ifixit site for Samsung U28E510 Motherboard . Is this motherboard have the audio amplify port to connect Samsung TV speakers?
Update (10/13/2019)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Robin Singh  possible but we need to see the main board. You can probably connect it to the audio IC if it is amplified. Post some good pictures of the board with your question so we can at least try to help you further iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
Not a good picture to identify the IC's but that board does not look like it has an audio amp. Can't really see it to well. Maybe take another picture just brighten it up and enlarge it.
さんによる
Pls find below URLs for motherboard picture & you can zoom it. https://d3nevzfk7ii3be.cloudfront.net/ig...
Samsung U28E510 Motherboard Replacement
Hope this will help.
さんによる
does your monitor have speakers right now?
さんによる
@oldturkey03 - No, only one audio jack for earphone. Want to install existing Samsung TV speakers in this monitor if possible instead of using external speakers through audio jack . Thanks
さんによる
Robin Singh you can't unless you get an amplifier first. Your board does not support speakers. You need an amp that you could install by the headphone jack and then install speakers. As is, does not work.
さんによる
コメントを追加
回答を追加する
Robin Singh さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 195
