メインコンテンツにスキップ
In August 2000, the ninth-generation Corolla was introduced in Japan, with edgier styling and more technology to bring the nameplate into the 21st century.
78回答 すべてを表示
I have problem with horn
I have problem with horn in corolla 2003. It work in remote finding on remote lock but it doesn't work on the steering wheel. I checked fuse and all seems fine. Also the clock inside the car shot down few weeks before that. After these issues happened I recently changed the battery nothing changed. Any idea?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
@mazetta this was moved from an answer you left to its own question
さんによる
コメントを追加
1 件の回答
There is probably more than one horn and maybe each one operates for a different purpose. As stated above, you can hot wire your horns to test the horns themself, then work your way backwards through the wires, to relays, to additional wires to fuses to your horn connector in the steering wheel. Relays are typically bad, you can swap same type relay from another system for temporary testing, no problem.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Maz さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 7
今までの合計 754
