Bought new charger tablet is not charging
I bought a new charger for my tablet and my tablet still won't charge how can I troubleshoot it to find out what's wrong if it's charging or the tablet
Did you check the charging port for damage? Look inside for bent/missing pins. Also plug in the cable and gently push up and down to see if the port itself is loose.
If you need a replacement port, the process will require micro-soldering.
このアンサーは役に立ちましたか?
Did you test the old and new charger for power at the plug that goes into the tablet?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 33
