メインコンテンツにスキップ
iMac Intel 27インチ EMC 2309 (Late 2009, Core 2 Duo 3.06もしくは3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHzもしくは Core i7 2.8 GHz) ID iMac11,1
522回答 すべてを表示
not video signal on iMac's LCD
Hi. I have got a 2309 iMar 27” late 2009. The iMac’s video card was broken. When I turned on the mac, the chime was heard, the screen lit up a bit, but nothing else happened even using an external monitor
Setp 1: Well, I changed video card, I turned on the iMac, chime was heard, the screen lit up a bit and I had video signal on external monitor, but not video signal on iMac’s LCD.
I was thinking that inverter was broken or a wire was bad connected. It was more easy to check wire connections but I do that without turning off the iMac and the vflex touched power supply and broke it (It was my fault, I should have rurned off the iMac).
Well, I changed power supply and I have got video signal on external monitor only and I was in step 1 again, then I changed inverter but nothing new happened.
I’m thinking that vflex wire brought electricity to the LCD and broke it, but I'm not sure why the iMac detects the LCD. In that case, it is any way to check LCD?
Maybe the LCD is broken.
any ideas?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
Hi!
Can anyone help me?  I have changed the power supply, the inverter and the screen, but I still can't fix it.  I need help please
さんによる
コメントを追加
1 件の回答
If you unplug external Monitor does it work?
Reseating ram can help with display issue sometimes but if it works on external it may well be that your LCD is broken or shorting out.
このアンサーは役に立ちましたか?
スコア 0
コメント:
anks for your response.
With external monitor unpluged iMac does not work.
I will try to reseat ram.
It is possible a shorting our on LCD when iMac can detect the LCD?
さんによる
コメントを追加
回答を追加する
Jorge Yerbito さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 55
