メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Hot Air repair, what temperature?
Hi:
My iPhone 6 is missing a backlight filter (near FPC connector?), I do not need to remove the motherboard from the phone for the repair. I have ordered replacements (2 spare FL2024). I have a hot air rework station and I have some experience with it but not with such a tiny part in a crowded area. I can also use the soldering pencil with a sharp point. I have headgear for magnifying but it is lacking for this part size.
What would be the best method for success? Best temp for the pencil and/or hot air? I have a very narrow air nozzle for the hot air. I am going to practice on a bad iPhone 5 motherboard but I would really appreciate opinions from those with this experience.
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
For Typical Lead-free solder, around 220c should do the trick.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi @teranz
For backlight filter repairs like this, I try to use the iron at about 400 - 450 Celsius so the solder melts quickly. If you are going to use the hot air rework gun, I have to recommend that you remove the board from the frame. The heat setting I use is upwards of 380 - 420 Celsius and this can cause flex cable and battery damage if the board is left inside the device.
As a side note, filters can technically be replaced with a jumper or a solder short since they are technically a fuse. You may find yourself having problems getting the small filter to stay in place and this is a working alternative to getting it to stay in place.
このアンサーは役に立ちましたか?
スコア 1
14 件のコメント:
Hi @refurbpro
Great info, thank You!
I was considering leaving the board in the phone since I watched a hot air video of that last night and it was successful. But your point about cable damage makes sense and I really do not want that. I will sharpen my soldering iron tip (my initial preferred method for this anyway) and practice on a bad iPhone 5 .
If I short across the filter pads will it cause noise to show on the screen? I thought about trying that.
さんによる
It's a great idea to practice before trying the real thing. Not everyone gets that opportunity! From my experience, the short fix doesn't cause any kind of back-light noise (I've done that fix at least 5 times).
I can say that it is much easier to do the filter fix with hot air as you are working with two microscopic solder pads... but it comes with the process of taking the board out of the phone.
One more side note: if you have any type of solder flux, its worth putting a drop on the filter before applying heat. This will make the whole repair a lot easier.
さんによる
Jeff:
After practicing my soldering some I decided to just try the jumping of where the filter would go on the motherboard. I used a small piece of #40 wire and was careful not to cause a short. After soldering the wire I tested the backlight line going to the connector and it showed continuity. I placed the positive probe on a ground and the negative probe to the backlight line of the connector and it read about 0.5 ohms, what I read it should be for the backlight diode. I connected the display and battery, the backlight came on dimly for a moment then went off. The area of the connectors AND where the backlight circuit is under the CPU shield got very warm quickly. I disconnected everything, verified no shorts, and tried it again. Same result. I disconnected the display and removed the jumper from the filter location, then reinstalled the display. As before, I tested the display function using a flashlight and it is working.
I Tested B+/Gnd for shorts- any suggestions appreciated!
Thanks!
さんによる
Is it possible to test for the backlight voltage (about 18 volts) if I remove the display and turn it on? Would this help?
さんによる
It is possible to test for the backlight voltage. This can be done by putting one probe on any grounded (shield) part of the board and touching the positive probe to any one of the backlight pins on the LCD connector.
Check closely around the connector for any type of possible short or pin damage as this jumper will remove the ability for a fuse to blow if high amps flow through the connector again. If these issues continue and you cannot verify that the solid 18-20v is coming through the backlight pins, there might be additional problems with the backlight circuit.
さんによる
9件以上のコメントを表示
コメントを追加
回答を追加する
Tom さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 27
今までの合計 2,235
