Broken pin in bose companion 2 series 111 left speaker pin cracked
How do I get a replacement plug for the left speaker as the pin in the plug is cracked
Based on pictures on the connector, you might be better off replacing the damaged part connector with a DC plug style system. Order up a DC male/female plug set like this one and solder one connector to the board where this weird “left” connector used to be. Then strip and solder the other adapter to the cable you have now. Should be a solid connection forever.
このアンサーは役に立ちましたか?
Oh right thanks for the reply. Is there anywhere you can just get another connector and solder it to the wire?
このアンサーは役に立ちましたか?
I don't know of any place that sells the OEM replacement connector. If I needed to fix this speaker for myself, I would upgrade to the universal DC connector.
looking for the same item, pin in left speaker plug broke
このアンサーは役に立ちましたか?
Exact Match could be
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 1,123
