メインコンテンツにスキップ
The Saturn Relay was the first and only minivan from the Saturn brand of American automaker General Motors and was built alongside its sisters, the Buick Terraza, the Chevrolet Uplander, and the Pontiac Montana SV6.
29回答 すべてを表示
The Driver's side sliding door can't be actuated by either FOB
When I put the new battery in the extra FOB it does not actuate the sliding door. The main FOB hasn’t been able to operate the Drivers side sliding door in 5 years. We’ve tried cleaning off the pins on the door and “plates” on the door frame that connect with the door pins. Nothing has fixed the problem, but the overhead buttons and door post buttons inside the vehicle do operate the Sliding door on drivers side. Any Ideas?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
If the FOB doesn't operate the sliding door, but the overhead button does, then the FOB is the problem.
さんによる
コメントを追加
1 件の回答
One FOB worked and one did not, sounds like a programming problem the original FOB sending unit could have been dropped and broken, now with a battery change killing the other makes no sense so I would be looking at a sending unit problem, reprogram 2 new units is my suggestion.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Stephen Blackstone さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 22
