Epson Home Cinema 1060 - No Motherboard Power
I have 2 Epson Home Cinema 1060 that show no signs of life (No Lights). Both have the same issue. The motherboards are dead. I swap with a working board and it works great.
Any ideas where to start on diagnosing the board? I can't find a fuse on this board.
Here is a photo of a working board.
この質問は役に立ちましたか?
4 件のコメント
The fuse probably does not look like a fuse, we will assume that you have a little electronics experience so follow the PCB from the power cable and look for an OPEN component, that may be your problem, a fuse that is not familiar to you.
Duane Donaldson さんによる
¿Number Part?.......
Andrew Jumbo さんによる
Hello. I have this same issue. I was wondering where u were able to find the new motherboard?
Tyler Shafer さんによる
I ended up selling these broken, but the guy who bought them from me said he got them working. He said it was a chip that regulates voltage to the main processor. I'm not sure exactly which chip, but that might get you a good idea what to look for. This must be a common issue with these projectors as I have now come across 7 of them with the same problem.
KDammen さんによる
