メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
モデル番号 A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7プロセッサ
190の回答 すべてを表示
Can you upgrade wifi card
I am wondering if it would be possible to put a more modern apple wifi card, for example from a 2017 iMac. I mainly want to do this for the Bluetooth connectivity, also would it be possible to add an SSD and lastly is 32gb ram possible on this model?
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
Nintendo Switch 修理キット
ゲームを再開するための、早くて簡単な修理キット
Switch 修理キットページへ
Switch 修理キットページへ
1 件の回答
選択されたソリューション
If you have a 2012 iMac then you already have a newer version of Bluetooth 4.0 (the current iMac’s offer 4.2) that as far as I know is fully compatible with everything being produced today. The newest version is called Bluetooth 5 and it is was just ratified and still very early for products.
While WiFi (802.11n) has been upgraded a few times current version (the current iMac offers 802.11ac) it would require more than the board to gain the higher throughput of the newest standards. MIMO requires more antenna’s than what your system has. The newest standard is WiFi 6 and it was just ratified and just being introduced
If you can’t directly wire your system to a hight speed Ethernet network directly you can still leverage it to connect to an external WiFi bridge which has the higher throughput WiFi (802.11ac)
この回答は役に立ちましたか?
スコア 2
コメント:
Ok thank you, I am mostly interested in getting the iMac to work with sidecar and unlock with apple watch which is incompatible with the hardware.
さんによる
コメントを追加
回答を追加する
David bellows さん、ありがとうございました!
統計データを表示:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 28
