メインコンテンツにスキップ
靴の修理、メンテナンスのガイド。足元を良い状態でおしゃれに保ちましょう。
36回答 すべてを表示
Is the insole too long in front, which first must be dot-dot-dot
I just bought these shoes used because this brand in a 10 M fits me without trying it on first. Also for financial reasons it was cheap.
Is the toe leather torn partly because the insole was just a little long putting pressure from inside on the toe? Obviously they scuffed the toe which caused it to tear through, but, to repair this toe, do I need to first remove the insole and shave a little off the toe?
2: what would be the cheapest, then easiest way to repair this tear once I do shave the toe of the insole if it needs to be done?
Thank you in advance for your help!
Update (09/28/2019)
THIS IS A PICTURE OF THE TORN TOE THAT NEEDS TO BE REPAIRED. DOESN'T THE INSOLE LOOK LIKE IT IS SLIGHTLY LONG AND CONTRIBUTED TO THE TEAR?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
What country do you live in friend where they do shoe repairs? When you say you bought it because its cheap, this is what happens with cheap shoes. I will also admit I buy on the cheap but I am also 100% sure they will not last for 1 year so I can afford to buy a $7 pair of good looking shoes every year. I bought a pair of $60 and they did not last for 18 months so cheap is all I get and throw them away every year.
Your picture does not look like a tear, it looks like a damage from rubbing your shoe on something probably by accident.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
D D さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 34
