メインコンテンツにスキップ
2015年3月にアップデートされたAppleのMacBook Pro 13" Retina Display Early 2015 はモデル番号はA1502、第5世代のIntel Core i5と i7プロセッサーが特長でForce Touchトラックパッドを備えています。
1185回答 すべてを表示
Have to put a lot of pressure on volume up key for it to work.
Hi there and thank you for taking a look at my question.
My Volume up key has been playing up recently in that I have to put a lot of pressure on it for anything to happen. I removed the key and gave it a quick clean but it doesn’t seem to do much. Has anybody else experienced this before and managed to fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Lets try this open your System Preferences under the Apple Icon, Open the Sound control panel, click on the Output tab at the bottom you should see the Output Volume slider. Now are you able to click on the Fn 10 & 11 keys getting the pointer to move side to side with normal pressure? If not then your keyboard button has failed and you’ll need to replace it.
Here’s the full Uppercase assembly MacBook Pro 13" Retina (Early 2015) Upper Case Assembly or if you are more skilled you can replace the discreet keyboard MacBook Pro 13" Retina (Late 2013-Early 2015) Keyboard. It’s a bit more work as the keyboard is both screwed and riveted to the case Macbook Pro 13" A1278 Keyboard Repair and Replacing. In either case you’ll need to get the uppercase out following this guide MacBook Pro 13" Retina Display Early 2015 の上部ケースの交換
MacBook Pro 13" Retina (Early 2015) Upper Case Assemblyの画像
製品
$269.99
MacBook Pro 13" Retina (Late 2013-Early 2015) Keyboardの画像
製品
$19.99
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Hi Dan! Thank you for replying. The key does work when you press it with a lot of pressure just not like the others. I appreciate your detailed response.
さんによる
コメントを追加
回答を追加する
Liam McK さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 84
