メインコンテンツにスキップ
2015年3月にアップデートされたAppleのMacBook Pro 13" Retina Display Early 2015 はモデル番号はA1502、第5世代のIntel Core i5と i7プロセッサーが特長でForce Touchトラックパッドを備えています。
622の回答 すべてを表示
Anybody know what the problem is?
hello, my nicely watched macbook pro 13 early 2015
one day just turn this no water no anything. If I plug into external monitor with hdmi the picture is great and everything works.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1回答
最も参考になった回答
It appears your display has failed. Do to the high cost of a replacement unit, I would first try calling Apple and ask them what a “Flat Rate” Depot repair would cost.
1-800-MYAPPLE
If you don’t mind please come back and tell us what they quoted you
この回答は役に立ちましたか?
スコア 3
コメント:
The T-CON logic at the very bottom of the display has failed.
による
That means I can only replace the logic board of lcd and I will fix the problem?
による
@luka11lavric - Just to give you an idea how difficult this is MacBook Pro Retina Display Teardown its just smarter to replace the entire display assembly than trying to replace the LDC panel!
Jump down to Step 9 the T-CON logic board is that little strip hanging off from the panel which you can't replace. It does the work of sending the signal to the panel.
I often encounter corrosion damage as people use a spray cleaner on the screen which then drips down. The proper way to clean the screen is to spray the cloth with the cleaner so you don't get any drips!
による
コメントを追加
回答を追加する
luka11lavric さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 16
今までの合計 16
