メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
Part of screen not working, same with lock button! Help!
My lock button hasn’t worked for a while but randomly the left lower part of the screen stopped responding to touch. I can’t unlock my phone because of my passcode and I can’t reset my phone either because assistive touch is located where the screen doesn’t work! What can I do?!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
I think you need a new screen. The repair guide lists the job as Difficult and there’s a lot of disassembly to do, but don’t be put off. So long as you’re well organised, make sure you note which particular screws came out in which steps so you can put them back correctly, and you have a fair bit of patience, it isn’t that hard. You just have to be very careful feeding the LCD and touchscreen cables through a slot in the midframe as there is a weak point on the inside of a bend in the ribbon where they can very easily tear. Having removed the old screen, practice reinstalling and removing it until you’ve mastered it before risking the new screen.
Or, you can take it into a shop - at that age the screen won’t be too expensive and it’ll be a fairly standard job for an experienced repair technician.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Mare lynch さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 37
