New midframe and proximity sensor not working
I just put a new midframe on a 3G and now the proximity sensor is not working. When I bought the midframe I was told it can be used on a 3G or 3GS.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
send it back, unless you think you have damaged your connection somehow?If you have changed the digitiser glass this may be the source of your problem and not the sensor as such. Also need to find out why you were changing the midframe in the first place as this may be part of your problem
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 640
1件のコメント
i was replacing it because the customer needed a new ear speaker. I replaced it with a new midframe. I have worked on these dozens of times so I doubt I damaged it. I took the old sensor out of the old midframe and will try to fix it today
mattgollini さんによる
