Macintosh Plus Trouble shooting.
I have had trouble with this machine a lot but i need a little help.
I noticed some broken solder mask and broken traces but i know those traces are not important because they go to the battery compartment. But i need to know why wont it start. When i turn it on it makes a Hi voltage sound. Like a Click-THUMP sound and then nothing happens. Sometimes it does it over and over again or just once.
When i power it off after the sound/s then power it on again the sound does not happen and there is no sign of life!
SYMPTOMS: A HI Voltage Click-thump sound , no startup BONG, No video or sound , and a black screen.
Also can someone give me the list of capacitors on the analog board?
Update (09/16/2019)
These are some broken traces
NOTE: not my image!
この質問は役に立ちましたか?
2 件のコメント
Are you sure they are broken and not the over-cover just isn't scratched. Did you check the continuity? Can you post your board so we can so how it looks do both sides and as detailed as you can.
Dan さんによる
I can get another computer for the same price as it would cost to fix this one and also that would give me a machine to test the analog and logic board on.
Bobby Gunnels さんによる
