メインコンテンツにスキップ
モデル番号A1502/2.6GHz(Turbo Boost使用時最大3.1GHz)もしくは2.8GHzTurbo Boost使用時最大3.3GHz)デュアルコアIntel Core i7、4MB共有L3キャッシュに変更可能
313の回答 すべてを表示
Turns off randomly when inactive & twice chime sound when turning on
I recently changed my SSD hard disk (according to instructions on Ifixit), to the respective OWC model, since my old one was failing more often than not. At the same time I upgraded to Mojave 10.14.6.
Ever since my computer turns off randomly, but always only when sleeping/ inactive and once I turn it back on, it does not only take about 5 times longer than before, but it actually does the chime sound twice until the apple logo shows up, so it seems to turn on twice in a row.
Otherwise it seems to run fine (apart from heating up quite a bit, but it did that before too).
Thanks in advance for any advice!
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
Check with OWC to see if your drives firmware is upto date.
による
コメントを追加
1回答
選択されたソリューション
“Compatible” flash drives are known to possibly give issues with sleep/hibernate on Macs of 2013/2014 years. The only workaround I know of is to disable hibernating through a set of terminal instructions. Normal sleep mode has a slightly higher energy consumption compared to hibernation but it would be worth a try to solve your issues. Or just replace your drive with an original one and everything should get back to normal.
この回答は役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Jay Dee さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 13
今までの合計 13
