Why does my iPhone reboot randomly after reassembly?
Hello!
About an hour ago I reassembled an iPhone 5s with a new Logic Board (that I previously bought from Ali Express) and used some parts from an iCloud Locked iPhone (which should be fine as the parts are all original). However, after reassembling the phone it boot perfectly fine to an iOS but after a few minutes/ hours (of a normal use) the phone reboots. Is it something that I did wrong while connecting things? Do you think I did something that would short out the logic board which causes all this reboot problem? How do i solve this problem?
この質問は役に立ちましたか?
2 件のコメント
By the way, the phone works (it loads the OS and you can even call from it, take pictures, etc. but then it just ¨dies¨ reboots)
Ali Sadykov さんによる
@as2019 And just so participants here get a clearer picture of the problem you are encountering, what exact procedures have you implemented on your own to rectify this situation you are dealing with? For example, have you taken the phone apart several times to find out where some re-installation omissions have occurred? Have you doubled checked during the subsequent disassembly and reassembly for component misalignment or misunderstanding of what exactly are the requirements required for specific components etc? Provide such details and maybe participants here will be clearer on the points that enable them to help you with over coming your problems.
prop man さんによる
