Why does my iPad Pro restart seemingly randomly, even when plugged in?
I have a 12.9-inch iPad Pro (1st gen I believe) that I like to use for sheet music. However, it suffers from the problem where it restarts, seemingly out of nowhere. After it reboots, the battery displays at 1% before going back to whatever level it was at before. This problem persists even when the iPad is plugged in or is at 100%. Besides this restarting issue, everything else seems to work fine.
The problem seems to happen less if I go for a long period of time (e.g. a week or more) without using the iPad, but as I use the iPad, the problem happens more and more often, eventually to the point where it does this around once a minute, making the iPad basically unusable.
I can try to record on video such a restart happening, if that would be of any use.
I visited an Apple store with this issue and there were no conclusive results.
Thank you.
この質問は役に立ちましたか?
4 件のコメント
"no conclusive results" but I suspect a recommendation as a starting point, yes? Sometimes biting the bullet and just going for it is the only answer. :-)
prop man さんによる
@propman Apple recommended just to buy a new one, but I’m hesitant to do so because the iPad is functional aside from the restarting, and the price is large. I’d (obviously) rather fix my current one if possible.
Comrade SparklePony さんによる
@sparklepony Seems funny that they wouldn't have recommended to install a new battery especially considering the age of the unit. Personally if I was wanting to fix the unit, that would be the first thing to be replaced, but then again I do all my own work on my own stuff. Others mileage might vary :-)
prop man さんによる
a video would be great thanks
edigitcom さんによる
