メインコンテンツにスキップ
AppleのPad 6のWi-Fiのみのモデルは2018年3月に発売されました。32GBと128GBの容量オプションがあります。9.7インチRetina ディスプレイと64ビットA10 fusionチップを搭載しています。
150回答 すべてを表示
My iPad 6th gen is bent... help!
So a few months ago I dropped my iPad and it flew out of its Survivor cover (I didn’t ensure all the clips were in when installing it) I picked it up to see what happened, surprisingly, it was still on with the app I was using on screen, but it had a severe bend in it, I checked to see if everything still worked, but when I tried touching the screen I noticed that one tap puts a heck of a lot of pressure on the LCD, I spend 1 and a half hours trying to unbend it, a bit of physical force and the help of heavy books it still didn’t unbend, I’m hoping to put some pocket money aside to get it repaired (or upgrade to a galaxy tab A) but I can’t find any repair guides nor shops that can fix my iPad without the risk of more physical damage.
Could someone plz tell me if it’s safe to go on a plane with an iPad with damage like this, I’m going to the airport this afternoon and I need the info ASAP.
I would upgrade but I need this iPad for school purposes
It’s also bulging out of its cover
here are some pics:
Thanks for all the help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hello. That should still be safe. The battery wouldn’t be very deformed with a bend that size. You don’t need to worry.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Bryn Trainor さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 684
