メインコンテンツにスキップ
In June 2017 Apple updated its 13" MacBook Air with a newer Broadwell Intel Core i5 processor, resulting in slightly increased performance and battery life.
144の回答 すべてを表示
Trackpad will not track on the upper right hand side
Hi, I have a Mac book and the trackpad on the upper right hand side will not track the cursor properly. There are some dead zones in the upper right hand side and some spots will cause the cursor to pause and then shake violently. The left hand side is completely unaffected. Another thing of note is that when I restart my computer the trackpad works again for a little while, but then gets worse over time, getting worse much quicker when using multi finger gestures, again only in the right hand side.
Is this the cable from the trackpad or is it moisture. I’ve tried using a blowdryer to only the trackpad. Did nothing. Or could it be the pad itself. Thanks
There is nothing wrong with the clicking function with the trackpad either.
Thanks
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
Android 修理キット
交換用スクリーンやバッテリーの修理キット
ショップを見る
Android 修理キット
ショップを見る
1 件の回答
選択されたソリューション
Sadly some of the liquid made its way into the sandwich of the layers and/or circuits within the trackpad so the sensors are not tracking. The best thing here is to just replace the part MacBook Air 13" (Mid 2013-2017) Trackpad. You may need to replace the cable as well if its corroded. Here’s the guide to replace it MacBook Air 13" Early 2015 トラックパッドの交換
MacBook Air 13" (Mid 2013-2017) Trackpad画像
製品
$49.99
この回答は役に立ちましたか?
スコア 2
コメント:
Thanks, I will order it now
by
コメントを追加
回答を追加する
Nick さん、ありがとうございました!
統計データを表示:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
今までの合計 15
