メインコンテンツにスキップ
2.0GHz, 2.3GHzもしくは2.6GHzクアッドコアIntel Core i7プロセッサ (Turbo Boost 最大3.8GHz) 6MB共有L3 キャッシュ付き。
580回答 すべてを表示
Where to buy display assembly or how to replace internal LCD panel?
iFixit hasn’t had any reasonably priced display assemblies for this model for years — when they had any at all…
  • Where can we source the LCD panel itself, rather than the much more rare assembly?
  • If we were to find the LCD panel — how might one do the swap/repair?
  • Lastly: I doubt there are any good answers (beyond “watch the ‘used’ markets) but where else might have legit/oem displays to purchase?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
You won’t find the LCD panel for this display or instructions on how to disassemble it, because the display assembly is the LCD panel. The aluminum casing itself is the back casing of the LCD, and the front glass on the display is the LCD itself. Even iFixit couldn’t disassemble it much more than it already is without breaking the glass. You can learn more about how the panel is assembled and why you’re stuck with replacing the whole thing in their teardown guide: MacBook Pro Retina Display Teardown
The iFixit pricing is a little on the expensive side but I wouldn’t call it unreasonable. Personally I buy displays from ProTech (https://www.protechrestore.com/index.php...) but I’m sure there are many options available.
Basically, you’re stuck with buying the full assembly :)
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
LCD panel also needs programming if EDID code is not accepted by MacOS auto brightness won't work and brightness adjustment won't work. Yeah these screens from experience cost me like $600-$800 AUD.
さんによる
コメントを追加
i’ve noticed a few used ones going for fairly cheap on ebay, not sure if they are any good but maybe a good place to find them.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
jasonbuechler さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 34
