メインコンテンツにスキップ
2.2 GHz (Turbo Boost up to 3.4 GHz) もしくは2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
254の回答 すべてを表示
My MacBook backlight is not working after water damage
I spilled some water on my Macbook, the computer worked well for a while, and suddenly the screen turned black. It never lighted up again.
Now it works perfectly with an external monitor. When I put a flash through the apple logo I can see the mouse cursor. What would be the problem and how should I fix it? Thanks in advance.
BTW, the display looks like this when I flash through the apple logo.
https://imgur.com/Q6iJWZ5
Here are some images when I opened it up. Any help would be appreciated.
https://imgur.com/a/4Ti6mjY
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1回答
最も参考になった回答
Your motherboard needs a Liquid Damage Treatment, can be a simple fuse or a Chip on the Motherboard. Somebody has to check it internally and do a diagnostic, or remove the back and take a picture we can help you.
この回答は役に立ちましたか?
スコア 1
コメント:
Thank you for the reply! Here are some images. Which side should I focus on?
による
Hi, i think is to late but here is the fuse location Backlight fuse and wled driver location on logical board a1398 2014 you can check it with a multimeter.
による
コメントを追加
回答を追加する
Junwei Sun さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 48
