Bottom of screen yellowish than top
Hello. Recently I bought brand new XR and it works perfect but I have one problem, the bottom of screen looks more yellowish than the top, what is the reason of that problem and how to fix it? Thanks
That usually happens after lcds are very old.if you replace it your problem will be solved.
このアンサーは役に立ちましたか?
if you just bought it new you should probably just return it for an exchange really. if you open the device to fix it they may not take it back
not really a “repair” solution I know. as far as what’s going on, as Owen said, it’s probably just an issue with the age of the LCD.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 141
