メインコンテンツにスキップ
2018年9月21日に発売されました。モデル番号A2097, A2098、GSM もしくはCDMA / eSIM もしくはナノSIM / 64, 256、512 GB / シルバー、ゴールド、スペースグレイ。(正しい発音は"iPhone 10 S.")
398回答 すべてを表示
iPhone stuck in recovery mode
I was trying to downgrade from the iOS 13 beta to iOS 12.4.1 but during the restore, there was an error and now it’s stuck in recovery mode no matter what I do. Whenever I try again I get the same “unexpected error (9)”. Everything is updated, I tried using a different cable, and turning off my antivirus (all things that came up when i looked up this problem). The error comes up at the “verifying iPhone software” stage of the restore.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
What's your computer's OS and iTunes version?
さんによる
コメントを追加
2件の回答
ベストアンサー
Error 9 could be indicative of a corrupted NAND IC. If you cannot get the phone through recovery via DFU mode, you may have a logic board issue (NAND) and only re-programming the NAND will get you device back in working order. This requires micro-soldering experience, is an advanced repair given the complexities of the X logic board configuration and requires a special programming device that few shops have on hand. Ask lot’s of questions before having it repaired and don’t trust low-ball shops.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
The “unexpected error (9)” message can be caused by the iOS device disconnecting during the restore process. There may be a way you can remedy the problem.
First, download the latest version of iTunes and download all pending updates to your computer.
Second, force your iPhone to restart.
Third, connect your iPhone to your computer using s USB cable.
Fourth, when iTunes asks you to Update or Restore, choose Update - NOT Restore - to reinstall iOS and keep your personal data.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Luke Lopez さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 650
