Hp 315 camera with display 000
I have an HP Photosmart 315 Digital Camera and the display window flashes three zeros 000 and I am unable to take photos. What do I do to correct this?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @evansiii ,
Try a reset and see if this resolves the problem.
Here’s the procedure:
Turn the camera off and then on again (slide the lens cover closed and then open).
Remove the batteries for approx.15 minutes and then reinstall them.
If you are using an AC power adapter, unplug the adapter from the camera, remove the batteries and then reinstall them after 15 minutes, and then plug the adapter in.
If it works, you will have to reset the date and time after this
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 7
過去 30 日: 7
今までの合計 120
1件のコメント
Nothing in your Owners Manual or HP site on error codes. Seems strange.
prop man さんによる
