メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
より早い処理スピードを可能にしたiPhone 3Gのアップグレード版です。このデバイスの修理は3Gと似ており、標準のドライバーと開口ツールが必要です。モデル番号 A1303 / 16 もしくは 32 GBの容量 / ブラックもしくはプラスチックの背面ケース
Home button doesn't work and doesn't charge when connected?
OK a few weeks ago I dropped my iPhone. At first it worked fine however, later on the home button stopped functioning and there was no more sound when recieving a call, message or playing music through the speakers. The sound works when I have the earphones plugged in however. Also when I hook it up to charge wheather it be on my laptop or with the charger nothing happens. And now it's run out of batteries. Apart that everything else worked before it ran out of batteries. I believe that it's just a dock replacement that I need however could there be something else?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
ベストアンサー
the iphone doesn't have any other battery/power. if your connection is damaged or loose there is no way of getting power to your battery...so in this case pressing the power button on a dead battery will not get a response. When you open the iphone to check your connector I would also test the output on your battery. If it is less than 2.6 it may be too dead to recharge, buy a new battery then you know that is good for a few more years yet.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
最も参考になった回答
The flex cable #4 simply has come loose. Carefully open iPhone and reconnect the Dock Port Flex Cable #4.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
OK thanks I will try that. However one more thing. Is it normal that even though it's ran out of batteries that when I press the power button I don't even get the sign or a response ? Could there be another problem there ?
さんによる
コメントを追加
回答を追加する
Chris さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 6
今までの合計 2,242
