iPhone 6s no turn
Hi the team
i have iPhone 6s
no turn see picture when i connect the Power supply
i have check u2 is working
he is not in dfu mode
You can help me please the team thanks a lot
この質問は役に立ちましたか?
Hi the team
i have iPhone 6s
この質問は役に立ちましたか?
When dealing with a “dead” phone, there is no "silver-bullet" solution. You have to probe the board to get a better understanding of what is working properly and what is not. It may be a simple solution or a complex one. Sometimes we see a visibly blown cap, replace and all is well. Other times, everything looks perfect yet the phone won't boot.
You have to start at the beginning and check PP_BATT_VCC, PP_VCC_MAIN and PP5V0_USB. I would start by checking to see if those rails are shorted to ground. If one of these rails is shorted to ground, then you will need to identify what is causing the short. It could be a bad decoupling capacitor, conductive debris or defective IC that is directly supplied by those rails.
Then you move onto the PMIC and check the voltage rails it generates:
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 68
1件のコメント
Did you do a Physical exam of the logic board what is its history
Did it for example get water damaged
Did you do a promp to boot.
edigitcom さんによる
