Released in 2017, the JBL E45BT are wireless on-ear headphones with Bluetooth 4.0 and 40 mm drivers, rated for 16 hours of battery life.
Gang Gang @ganggang66530
評価: 1
投稿日: 2019年8月20日
Everytime I try charging my headphones the red light doesn’t turn on and they won’t turn on anymore.
この質問は役に立ちましたか?
Gang Gang follow the advise from @propman after that you also want to consider replacing your battery.
oldturkey03 さんによる2019年8月20日
prop man @propman
評価: 1.1千
3
Sounds like you need to do some troubleshooting with a multimeter to check voltage levels coming from your charger and also disassemble the headphones to make sure the charging port is ok, correct voltages are present etc.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,517
1件のコメント
oldturkey03 さんによる
