メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
2017年9月22日発売。モデル番号はA1864, A1897。GSM もしくはCDMA/容量は64もしくは256GB/仕上げはゴールド、シルバー、スペースグレイ。
492の回答 すべてを表示
Squares on front facing camera don't line up with plastic on screen
I have just got a front camera replacement for my iPhone 8 Plus and the two squares on the front camera that need to go in the plastic part of the screen do not stay in. They just pop out straight away! Any ideas?
I am referring to parts 7:40 to 8:02 of this video;
https://www.youtube.com/watch?v=2sD9dv-y...
Thanks, help would be hugely appreciated :)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
They often time have problems fitting. You can try to gently peel out the plastic pieces and put them over the square sensors first. The only issue I’ve seen with that is taking those out might cause a scratch on the color paint and it will be visible from the front of the screen. If you try that, use a plastic/nylon spudger to pry those pieces off. Sometimes it just takes some jiggling those square pieces around until you get them in. You may have to push firmly to get them in.
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Rafay Siddiqui さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 26
