メインコンテンツにスキップ
Repair information for graphic tablets. Graphic tablets are also known as digitizers, drawing tablets, drawing pads, digital drawing tablets, pen tablets, or digital artboards.
33回答 すべてを表示
huion 1060 pro won't turn on
i just dropped my tablet and i’m worried i totally broke it. it won’t respond at all. the led light wont turn on, none of the keys register, the pen doesn’t register, and it doesn’t show up as being connected to my computer.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Sounds like the unit’s housing probably needs to be opened up and the interior inspected for damage, loose connections, cold solder joints that have cracked due to the shock of dropping it, etc. If it’s under warranty you could try claiming a repair but more than likely if there is any indication it’s been dropped, the manufacturer will not cover the repair. If you are interested in trying to repair the unit yourself you may need initially some form of “spudger” tool(s) to open the unit. This site and others like Amazon have kits, such as the following, which can be purchased.
Essential Electronics Toolkit
That all said and done, you may find it is easier and more economical in the long run to just buy a new unit. Wish I could be of more help.
Essential Electronics Toolkitの画像
製品
$29.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Catlyn Leonard さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 857
