combine parts for one functioning phone
Have two iphone7’s parts and want to build ONE. One is black listed and the other works with AT&T. What part do I
need to keep for the service to continue with AT&T
この質問は役に立ちましたか?
この質問は役に立ちましたか?
All parts are swappable except for the home button. Logic board chips are another story.
このアンサーは役に立ちましたか?
So what part do I keep that ties me to my service provider?
CPU, Baseband, EEPROM, nand and wifi ic's
Hi @lindian
The main logic board contains all the chips and memory from the iPhone and will work just the same in a different frame/housing. That is the part you will need. The home button has Touch ID functions that are paired with that logic board so it will need to be transferred to your rebuilt iPhone as well (it simply pushes out of the front glass after taking out some screws).
This is what your main logic board looks like
This is what your home button looks like
If the LCD assembly is good, you can simply use the whole screen instead of just home buttons.
Best of luck!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 56
