メインコンテンツにスキップ
A collection of guides and support to help with washer repair.
3466回答 すべてを表示
GE Profile WPRE8150K2WT grinding and spewing bits of rubber
My GE washer has been making grinding noises on and off for a few months. The other day I found a bunch of small dark bits of stuff in the tub when the wash finished, which I figured was from something my husband left in his pocket. It just happened again and I realized that those dark bits were actually small pieces of rubber that must have come from inside the machine. Yikes! Clearly this is a serious problem. Is there a solution?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Those little pieces of rubber are from the center seal. The grinding is from the center bearings. If I was C.S.I. the cause of bearing noise is due to the seal leaking and water eroding the bearings. But I’m not CSI and I’m not there , although there isn’t anything else that would cause thes exact symptoms . You might notice some water ad oil under the washer too
This washer would need new center seal, and bearings. I’d take a good look at the gear box. Water could have mixed with the oil. Sometimes when bearings fail the threads on the drive shaft and agitator get damaged. If damaged, they’d need replaced. The repair cost at that point wouldn’t be cost efficient. Put your money on a new washer.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
Sounds to me like the tub bearing has failed and caused damage to the tub seal. But let’s get another opinion from @ladytech first
https://www.repairclinic.com/PartDetail/...
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
I believe your correct Mayer! The grinding is the bearings. The seal started leaking long ago, damaging the bearings til they got so badly damaged that the seal broke down. That drive shaft is probably rusted to the bearings.
Hope all is going good for you!
さんによる
Thanks so much for responding.
さんによる
@bqbarnard Hope this info helped you ;-)
さんによる
コメントを追加
回答を追加する
Elizabeth Barnard さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 46
今までの合計 1,224
