Washer is not draining and is making noise.
My mom's Cabrio Top Loading Washer isn't draining and is making a noise that sounds like an old neon sign. I don't think the drain pump failed because it's been replaced in the last year. It also sounds off balance during the wash cycle.
この質問は役に立ちましたか?
2 件のコメント
the neon sign-like noise you mentioned sounds like the motor failing when energized.
Tony さんによる
If it sounds like humming, then something got stuck in the pump https://howtofixit.net/washing-machine-w...
Mark Lubinski さんによる
