OS Lion is available for download
Lion became available this morning. At 9:05 it took 20 minutes. Download time is running an hour and forty five minutes. No telling how long it will take once email notifications are sent out. Just wanted to notify ya'll.
The incapacity of Lion to allow the functioning of the Power PC applications may be a major problem, the problem is the abandonment of Rosetta. Rosetta allows Power PC apps to run with an Intel processor. Before doing this update, it would be wise to check which applications, which small utilities will not function any more and to benefit from it to do the housekeeping or to find an equivalent with the Intel code of it.
CultOfMac offers a simple solution to track all this software. Make the following command in the terminal:
system_profiler SPApplicationsDataType >~/Desktop/MyFileTypes.txt
It will create on your desk a textual file " MyFileTypes.txt" that will contain all the list of the applications of your computer. Open and do a search for the occurrence " Kind: PowerPC".
All the software that have this label will not function on Lion.
For those who still imperatively need a Power PC application and who want nevertheless to upgrade to Lion, I suggest that they keep a partition Snow Leopard on their machine.
I ran this Terminal command and the list of programs that won't work on my machine was very extensive. Even my Adobe CS 2 won't work. I'll be installing this system on something that doesn't matter. This appears worse than my transition from system 9 and the loss of all those programs collected for so many years. I'm very disappointed with this revelation of Lion.
UPDATE
Lion is not a upgrade only. It will install a full version. I tried burning it onto a DVD but got media errors twice. I moved it to an external firewire drive to move it around. I didn't think it installed at first, it gives you an app that tells you what programs won't run with it. It requires a couple of restarts to install. The install took 22 minutes. It automatically opens migration assistant on the first boot.
To my surprise, migration assistant moved over all the apps that it says won't work so I will have to go in and clean them all out.
この質問は役に立ちましたか?
14 件のコメント
As an owner of Parallels Desktop 5 (or earlier version) you will need to upgrade to Parallels Desktop 6 in order to have compatibility with Mac OS X Lion (10.7) $39.00
mayer さんによる
iWork's '09 now requires an immediate serial number. Before you could register it later or not at all. I haven't tried iLife '11 yet.
mayer さんによる
My Sonnet PCI ethernet card will not work with 10.7.
mayer さんによる
Great new tool, helps with not having DVD drives - - Start up using Command R - you can now run Disk Utilities without booting from a system disk and make repairs
mayer さんによる
Sonnet just posted a Compatibility Matrix on its cards: http://www.sonnettech.com/support/lion/i...
mayer さんによる
9件以上のコメントを表示
