メインコンテンツにスキップ
モデル番号 A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7プロセッサ
212回答 すべてを表示
Why is my iMac working so slowly? 2012 iMac macOS Sierra 10.12.6
My machine is working very slowly and I am unsure why. Even loading a webpage in chrome or starting up spotify takes ages.
I have 787.24GB available of 999.35GB for storage. 8GB of memory installed. I have tried emptying the trash and some other things with no luck.
Any help would be great.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Start up in Safe Mode by holding down the Shift key on start up and let us know if your problem persists.
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
Ok, I will. Would you recommend doing that before running something like Malwarebytes?
さんによる
I always do the things that don't cost first. Besides, it doesn't get much simpler.
さんによる
So I gave it a shot. Things seem to be loading faster, but it is doing this weird "painting" behavior. The login screen was painting up the screen over and over, and each application I open is doing it as well. Even after the application has loaded. Websites appear blank as well. As if it cannot fully load. Safe mode seems worse right now
さんによる
That sounds like a failing GPU. Hook up an external monitor and see if it is doing it there too.
さんによる
I do not have an external monitor :/
さんによる
1以上のコメントを表示
コメントを追加
Have you tried running an antivirus scan with malwarebytes or another program?
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
No I haven't. Would you recommend that program vs others?
さんによる
Malwarebytes is free and has worked well for me in the past
さんによる
コメントを追加
回答を追加する
Mike Aiello さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 83
