メインコンテンツにスキップ
4インチディスプレイ/カラーバリエーションは様々あり/3種のモデル/16, 32もしくは64 GB容量
331回答 すべてを表示
Won't turn on after succes battery change.
I everyone. Hope to got help whit this on. I recentrly change de battery of an iPod touch 5th gen succesfully, but after i power it of it won’t turn on again.
After the battery replacement the iPod was working but it was lock and i didn’t know the code so before i ask the person the code and get the answer i decide to power off the device. Surprise when i get the code the iPod won’t turn on, try the 15 second home/power hold nothing. try to charge it for the night, nothing. finaly try to let it fully discharge for two week then plug it and re-tri the button hold and nothing.
Wish you guys have something that could help me revive that device.
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
need to check if it is charging first . get a usb ammenter
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
What do you mean ???
さんによる
https://store.ipadrehab.com/USB-Ammeter-...
you first step to a charging problem
さんによる
Finally get my usb ammenter and test my iPod. Looks like no charging. Does that mean automatically that my charging port is dead or there's some trouble shooting i could do?? Before battery change was supposed to work (that's what the personne told me). Could it be just a bad connection ??
Thanks for any advised
さんによる
コメントを追加
Sounds like battery may not have been bad afterall, might be charge port, charger, or wire, so try different charge equipment to see if something might work. There is also a total reset option that you might try, resets and restarts everything.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Will try other cable and charger but those are working perfectly for my iPhone so why not for the iPod. Read something about jumpstart or something like that (i know on iPod touch 4 after screen replacement sometime you have to short the battery with the charging port frame) or maybe could you tell me more about the total reset option or a link to a guide ??
thanks
さんによる
Similar happened to me once on ipad, had to reopen and unplug battery to make it reset. I can't recall, but total reset was to hold volume down and power button till it restarted on my iphone 7plus. I think it was dirt and grime in the charge port or something of that nature, as it's working ever since. Good luck
さんによる
コメントを追加
回答を追加する
Stephane さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 138
