Turned off washing machine when a cycle was on. CL light came on.
CL light came on where the cycle time is shown. Washer stopped working.
Deokie Hosein this error code indicates that the CONTROL LOCK has been activated. To deactivate the control lock press and hold the drain and spin button for 5 seconds. Or you can try to reset it by unplugging your machine, and plug it back in after 5-10 min.
このアンサーは役に立ちましたか?
Hey Doekie. I believe that would be a "Child Lock". You only need to clear the code. If you have the owners manual it likely covers this, otherwise you could provide the model number for your machine we'll see if we can't come up with the exact steps for that washer.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 39
