Hoe van I prevent Light bleeding?
So i replaced lcd of my iPhone 5s. And in darker backgrounds u see Light bleeding from the edges. How can i fix this?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Usually it’s due to the quality of the replacement screen.
Have you made sure the housing doesn’t have any debris on the edges and the housing is not bent or dented on that area where it’s showing backlight bleed as that will make the screen not sit flat at that spot?
このアンサーは役に立ちましたか?
There was a slight bend in that corner. Thank you so much.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 77
