メインコンテンツにスキップ
Fix Your Stuff
Right to Repair
Parts & Tools
Appleによって発売されたハイパフォーマンス用のタブレットコンピューター
276の回答 すべてを表示
Changing screen and lcd
Hi, I broke my ipad pro 12.9” screen model a1670. If I buy the new one that offers fullset, will my touch id still works? Because if I have to do some soldering, I don't have the abilty.. Someone says that the ipad pro middle flexible locaten on the screen is crutial so we have to include the old one to the new one.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
In order to retain touch ID functionality, you need to salvage original home button from broken screen and transfer to the new one.
Buy a replacement screen with daughterboard pre-installed (‘the middle flex’ circled in picture) to save yourself the hassle of soldering, from any reputable vendors like iFixit and MobileSentrix.
Follow this guide for disassembly of device: iPad Pro 12.9" Display Assembly Replacement
Follow @refectio guideline in his answer to this post for re-assembly: After doing my repairs (battery and screen) I have problems
この回答は役に立ちましたか?
スコア 2
コメント:
Does the picture I posted is the correct display for the ipad rpo 12.9 a1670? Or is it for the a1671?
さんによる
@Nic Yaakov Durant, Sr A1670, A1671, and A1821 are three model numbers for iPad Pro 12.9" 2nd Gen, they use the same screen assembly. I can't really tell which one you have just by looking at that picture.
さんによる
Hello sammyz I currently have an iPad Pro 2nd gen 12.9 A1671. I sent about two emails regarding this issue and they just kept telling me that they didn’t know. And last night I got another email saying that the part I had picked out that cost about 399$ (Item code IF323-030-1)is the one that includes the daughter board. However, he is not sure if additional soldering will be required. I want to fix it really bad because I use it to take notes at UNI. But the little cracks get in the way. My Apple Pencil rubber tip is like gone now. Hope you can get Yours fixed Nic D. And if you do LET ME KNOW PLEASE!!!
さんによる
コメントを追加
回答を追加する
Nic Yaakov Durant, Sr さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 42
