After OS installation unable to use the machine
OS installation done I have chose the country , after chose the key board layout the we got the error “A Critical Software update is required for your Mac, but an error was encountered while installing this update After that I had connected with WiFi or Ethernet Port and try to update the OS but round and round circle is going on after few second same massage appear.
Please HELP…….
3 件のコメント
What is the macOS you are trying to install? How big is your storage and how much free space do you have?
Do you have access to a second Mac as well as a USB Thumb Drive which works across both. Or a USB-A to USB-C adapter cable to interconnect the two?
Dan さんによる
I had installed OS version 10.14.5. Installation was completed. Storage is 512GB around 400GB free Space .unable to access the Second Mac
Moinul Haque さんによる
Why did you reinstall the OS ? Does the touchbar turn on now ? What about keyboard backlight ?
I had the same issue but i didn’t reinstall OS, it happened itself. Apparently Touchbar died and it caused Critical Software update error. It was booting fine in safe mode though, except i did not have touch bar or keyboard backlight at all. I had the top case replaced under keyboard service program. Now everything is fine.
Gentrit Abazi さんによる
