メインコンテンツにスキップ
2017年4月に発売されたSamsungの新しいフラグシップのスマートフォン、Galaxy S8です。
304回答 すべてを表示
Do I need to do anything in the software after replacing the battery?
I used AccuBattery to estimate my battery capacity before replacing it and I was getting around 2500 mAh. Now after replacing the battery my battery life is significantly worse and the app now estimates the capacity is only 2100 mAh. Do I need to do anything in the OS to calibrate the battery after replacement?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Hi @rogertiu ,
after this change, you can calibrate your battery, but it’s not necessary. I don’t know, where did you buy your new battery, but the capacity of a brand new battery from manufacturing is having a higher capacity then it is written in the description of the phone. On the contrary, every next battery will have a smaller capacity, especially batteries from “non-original services” will have much lower capacity, then original.
Anyway, there are tips for calibrate your battery with rooted and without rooted device.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Thanks for the information! I purchased the kit from ifixit. I will contact them to see if they can help.
さんによる
@rogertiu You are welcome! Good luck, let us know, how does it go.
さんによる
コメントを追加
回答を追加する
Roger Tiu さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 87
