Where can I get the glass screen for the Moto G7?
Looking for the Moto G7 screen repair kit.
You need a glass only panel? Or the whole screen?
Whole part: https://www.ebay.com/itm/OEM-Motorola-Mo...
Glass only: https://www.ebay.com/itm/For-Motorola-Mo...
For adhesive you will need Double Side Adhesive tape.
Ifixit doesn’t carry your part yet. Be sure to buy the iOpener set with tools as its enough to do the job unless there is any special screw in (aka if you have a protech toolkit it will be helpful plus a cool gadget is never bad.
https://www.youtube.com/watch?v=Mnw6LGOi... is the tutorial of replacement.
このアンサーは役に立ちましたか?
You will need a T5 bit to remove the bracket. iFixit Precision 4 mm Screwdriver Bit Select T5 and iOpener . Use pressure removing the screws else it will strip
My screen is shattered so I would need the screen.
Choose ur parts and order ur needed tools from Here
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 4,193
