メインコンテンツにスキップ
Apple AirPodsは2016年12月に発売されたワイヤレスヘッドホンです。
94回答 すべてを表示
incredibly low volume and a ton of sound leakage
ok so ill get it out of the way with the general unpairing and repairing or the reset your AirPods or to suck on them. tried em all. any guide on the internet on how to fix this has not helped me what so ever. so in summary my AirPods when I use them are to the point its a struggle to listen properly to music when the volume is at 100%. also when im using them at 100% volume people around me can hair what im playing way louder then I can. not only that. this is my second pair of AirPods. the same happened to the first pair then I got them replaced. unfortunately its now too late to get these replaced too. does anyone have any ideas about where I should go from here? or do I give up and just take it too apple and see what they can do.
thanks in advance for any responses
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
With very low volume, I fixed mine by using isopropyl alcohol and a qtip/ear bud. Gave it a good deep clean and restored sound perfectly for me.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
hi there. thanks for the response but unfortunetly thats something I've tried too. sadly didn't work either but ill admit the volume was slightly better for a day then went down hill again after. volume still wasn't as good as it could have been. thank you anyways
さんによる
@Finnlay Worchurst not a problem, just thought I would share something that worked for me.
さんによる
コメントを追加
回答を追加する
Finnlay Worchurst さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 67
今までの合計 3,675
